Ford only part?
alienturtle
Human
Ripon, CA
My 4x4 and low range switch that triggers the lights on the dash has taken a poop in my tcase. I called the local autozone and kragen and they told me its a dealer item only. also looked on rockauto and could not locate it. Dealer only item?
phazertwo
Die Summer DIE!
Crawlorado!
sounds like junk yard only piece. No way I would pay for that from a dealer, they would eat your wallet for it.
PZ
alienturtle
Human
Ripon, CA
i think thats what i am going to have to do. cant seem to find one online anywhere.. Im also going to pull the switch out and see if maybe i can clean it.
Cucamongan
Huh?
Rancho Cucamonga, CA
Are you sure its the switch or the actuator?
x2 on the Boneyard part.
Do you have a pic of it? maybe you can get it off a Bronco as well.
alienturtle
Human
Ripon, CA
yeah. I have to get under there and see what BW t case i have. thanks guys. i wasnt sure if i was just missing it cookoo
dyoung14
Is getting worn out
spencer,tn
I have a question now, on my 89 the low range light doesnt work on the one that says 4x4, and when i pull it in 4lo it still just lites up 4x4 in the dash
alienturtle
Human
Ripon, CA
That is the way it is soposed to operate. When you click into 4x4 the 4x4 light will come on. Then when u go down into low range the 4x4 light as well as the low range light should be on at the same time
dyoung14
Is getting worn out
spencer,tn
I ment to say my 4lo light doesnt come on, just the 4x4 light
alienturtle
Human
Ripon, CA
oo hahahah i get it..lol cookoo sorry. that is exactly what mine is doing right now. now if you get under your truck and un plug the connector from the tcase. take a paper clip and stick it in one of the pins or both if you want both lights to come on. then ground it. turn on your key and if the light come on then its the switch. thats the problem im having just my 4x4 light comes on but if i ground both wires at the plug my 4x4 and low both come on at the dash so i know its the switch.
biggin92
Yeeeee Haaawwww
umatilla fl
If you have a 1356 i have one here that works that i can send you if you would like.;Sweet
bigblue85
Vallonia/IN/USA
definatly wouldnt buy it from a dealer i priced a hub that my local junkyards didnt even have that i sheared and they watned 698$ well had to order it from a junkyard 50 miles away...for only 55$...broke two shock mounts on the rear and one on the front in the same month and only place i could get them from new was ford dealer and it cost me 180$ well i couldnt get a used rear shock mount because they are industrial riveted to the frame and they were all rusted out anyway...the front lower shock mounts from the junk yards had the traditional hey im worn out bend that almost touched the axle so i just bought it new also...so only thing i would get from the dealer is a sucker out of the jar at the parts desk lol
