F-450 Parts
AZDIRT
Kingsford, MI
Dana 80 Rr Axle, Frt I-Beam Axle, Trans Mtd Brake, ***Poss Deliv to IL,IN,OH,KY,WV***
UPDATED - Everything went to scrap except:
Dana 80 Rear Axle - $400
Front I-Beam Axle - $100
Full Set of 10-Lug Wheels with Tires (tires have ok tread but are weatherchecked) - $150
Trans Mounted E-Brake - $350
***I know it is last minute, but I will be driving from Milwaukee, WI to Charleston, WV, leaving Noon on Sunday the 23rd for arrival in Charleston around Noon on Monday. I will then be leaving Charleston Monday evening and beginning the trip back to Milwaukee. Mapquest the route, and if you are close we can probably meet or work something out. Call me at my cell number 906-458-2405 ASAP if you are interested in doing this!
Thanks
Parting out F-450. Originally was a bucket truck. 2wd, auto trans, under 200,000 mi. So far, Injector Hard Lines, hydroboost, air cleaner, and fuel filter receiver are gone. Also alternator and fan clutch are gone. I am keeping the rear springs, maybe the fronts, and the doors for another project. Everything else is up for grabs, make an offer on anything you don't see listed.
Cab And All Interior Parts - $175
Front Clip - $150
7.3 NA, minus above parts- $200, had problem dying out after remanned injectors were installed.
E4OD - SOLD
Trans E-Brake - $350
Dana 80 37 Spline Rear Axle - $400 (Less than 5000 mi on new Calipers and Brake Shoes)
I-Beam Front Axle - $100
Set of 6 10 lug wheels with tires - $150
Take a look at the pictures, pretty much everything is for sale:
See picture post below.
ALSO: The F450 Is dissassembled now. Cab, front clip, engine, axles are ready to load.
Everything is located in Quinnesec, MI 49876.
Thanks
Dan
9O6-458-24O5
AZDIRT
Kingsford, MI
The only thing that sold so far is the trans. Make me an offer, lots of good parts here.
What doesn't go in the next couple weeks will be scrapped.
Thanks
Dan
AZDIRT
Kingsford, MI
Apparently I deleted the pics link when I deleted the the links to the ebay auctions.
It is back now, in the original post.
AZDIRT
Kingsford, MI
10 Lug, Disc, with new calipers and shoes.
Ratio is 5.xx, either 5.13 or 5.38.
Also, I know where there is a Detroit for this axle.
Thanks
Dan
AZDIRT
Kingsford, MI
Complete cab, front clip, hood, front axle & springs, engine, pretty much everything except the rear axle will be going to the scrap yard in about a week and a half, so make offers, let me know what you might need.
Truck is completely disassembled.
AZDIRT
Kingsford, MI
Interior is good and complete, there is through rust in a line between the drivers rocker and floor. some rust on pass side rocker, not too bad. Also some rust on the cab corners, but not through.
It's better than a lot I see in Michigan, but would need a little work.
AZDIRT
Kingsford, MI
hesutton
The Anti-Anderson
Bowling Green, KY
Man, if you weren't in the upper peninsula of Michigan, I'd have bought that axle 2 weeks ago. I just can find a way to get it from that far north to Kentucky without killing my "toy" budget.
Heath
Staff online
