External engine heaters
CDX825
filtration nut
Litchfield,Ohio
So lone long as its just a heating element its not going to care if its AC or DC. That means 110-120 volts AC or DC though. If it a 12 Volt heating element your looking for I know they make 12 volt water heater elements.
CDX825
filtration nut
Litchfield,Ohio
So long as the heater is rated at the voltage you plan on running it on it will be fine.
