built4tq1
well,seem to have yet another question for you brainiacs aboard this vessel. Im having vibration problems on the old 7.3. Its been getting worse as time goes by. The truck has about 140k on her and has new head gaskets, injectors and glow plugs, Now i have tried what i can to pin point this vibration and have failed thus far. The truck idles right at 750 rpm with no misses or hiccups. However this vibration at idle is bad enough that it shakes the truck to the point that you can see the mirrors moving and here an assortment of rattles. If you pop the hood and look at the engine while vibrating it will play tricks on your eyes. Funny thing is though once i rev the engine from 750 to 850 the vibration is almost absent. I have checked my torque converter and flex-plate. I've inspected the harmonic balancer seems kosher,I have even pulled all the v belts of the engine to see if maybe it was something in the accessories and...yeah..still vibrates. If your in the vehicle in put her in gear the vibration will intensify. (seems the lower rpm's are the worse it gets) Motor mounts checked out fine to by the way. I'm lost at this point, could it be trans related? torque converter? I'm not sure, which is why i have submitted yet another question to what i believe to be the most knowledgeable diesel forum on the net. Thanks everyone
