Any turbo block will have 1/4 inch oil port plugs. All other blocks be it 6.9 or 7.3 non turbo blocks have 1/8 oil port plugs. The first turbo block has a serial number of 1,116,331 and goes up from there. Below that and you do not have a turbo block. Now after teling all that, you still can't know for certain if the block has the inconel exhaust valves or the 33mm pioton pins. Any idi engine can run either Vbelts or serpentine belts. All the blocks are drilled the same so al the acessarys fit both turbo or non turbo engines. Find the block serial number just to the drivers side of the injection pump and post them here.
