E4OD manual kit?
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Does anyone make a manual conversion kit for a E4OD?I know Transgo has a kit to convert the C6 into a Semi Auto where you manually shift it with the auto shift lever.Looking for something that will allow me to stay locked in a gear no matter how hard I press the throttle(hee hee hee,SMOKEM) and shift when I want it to.
Freight_Train
Gadsden,Al
That is great for a street truck but I want the quickness of a auto but the control of a manual for the Enterprise that might see strip duty a few times.
obinella
baja- okie, errrr baja ******, errr okie ******, and omb were hawking a setup that they though was real good. contact omb or do a search.
highest_vision
Reqistered User
Boone, North Carolina
clicky from summit. Says in cataloge "Get 1st, 2nd or 3rd gear to hold at any rpm with this kit, plus firm full throttle shifts. The kit also includes an option to convert any E4OD to full manual control for off roaf/racing { :rolleyes: } applications."
There are probably more out there.
James
tuckerd1
WAR DAMN EAGLE!
Princeton, AL
The TCS Baumanator that OKG has claims the following
The ManuTronic function allows manual gear selection via the original equipment speed control (cruise control) switches. This feature allows up and down-shifting through all four gears at any time, using the Accel and Coast buttons located on the steering wheel. Initiation of this mode requires pressing the Coast and Off buttons in sequence, allowing it to coexist with the speed control system while being mutually exclusive of it.
This sounds like a good, easy to use setup for manual shift.
