Dual Batteries
Macrobb
North Idaho
It's not all about cell voltage, it's also about the internal resistance of the battery. This internal resistance increases as the battery ages. So when you ask the battery for high output, the older battery will have a higher internal resistance, so it contributes less when paired to a better battery with less usage cycles on it.
I have no disagreement with this statement.
A battery doesn't have to be "shot" to lag behind and drag down and hinder the performance of a good battery.
Not helping is not the same as hindering. I'm saying what you said above. You may not get peak performance, but you'll get somewhere between the best battery's performance and 2x that depending on how much the worse battery can supply.
It's still not going to be /less/ than the best battery by itself, without a shorted cell.
WVAiredales
Kenna WV
Autocraft gold or duralast gold? Both are 65 with 850 cold cranking amps
Thank you
Shawn
Two batteries from Walmart have been in my truck for several years now. Doing good.
Bradz
