Dream Truck
BuckinBronco
NY
If money, time, and parts were no object, how would you build your truck? If you were given a blank slate, what would you do with it?
fordf350man
Rockwood MI
something similar to this for me, not exact but close
justinray
Contributor
Cleveland, Tx
Crew Cab, Long Bed, SRW, Ford Blue, 7.3 sleeved to 6.9, stroked 20 thou', drop comp to 20:1, headstds, main studs, manifold studs, typ4 cam, custom turbo and intercooler to run a cool 30 psi, rodney red radiator with 2-14" fans and 2-12" fans, aux oil cooler, aux power steering cooler, dual alternators, electric vacuum pump, hydroboost, custom dash with onboard inverter radar detector 12 gauge setup and everything on toggles/buttons, 6:1 t19 w/ranger overdrive, and ranger underdrive, bw1356 W/gearvendors overdrive, dana 60 kingpin front w/ sterling 10.5" rear w/ drw drum brakes, and 5.13 gears. I think I covered everything.
smokin150
aka Diesel Weasel
Hedgesville, WV
THIS!!!! ;Sweet;burnout
Wyreth
Certifiable Noob
Las Vegas, Nv
Rebuild, re-bore block and heads for 1/2" hardware, heads and block machined for mythical fire rings and fire rings installed. A 4wd conversion, I havn't decided which yet. zf6 (money is no object right?) with brownie 3 speed (ud/direct/od) then divorced transfer case. For the engine, an inline pump off a international 9L. Custom designed boost controller working a parallel pair of VGT turbos (never looked at the type, because I will NEVER have the money for something like that) Fabriate myself an intake manifold. Water/air intercooler, with water/**** injection. Also, depending on if I ever experiment with it, and it actually works... a throttle demand exhost manifold water injection as well (steam to spool the turbo faster on accel) Front bench from a Towncar, a Toyota climate control system. (sorry, but I really hate the ford one I have in my towncar) Rear bench lift, possibly rear bench/bed system. A COMPLEATLY removable 5th wheel hitch, and a pop up goose neck. Epump system (that I still havn't decided on) Custom built LED euro compliant headlights. (ish building a set for my supra, why not use them on the truck too?) 6k winch in front, and 8K in back.
That's all I can think of right now.
kc0stp
30 Hour Famine
Colorado
If I could only do 1. bricknose crew cab dually with super singles, 97 6.9 with cam, studs, valve springs, coated pistons, RD4 180cc pump, A3K turbo, intercooler, road ranger 10speed, divorced t-case, 10.25 with ARB locker, Dana 60 with ARB locker, on board air, 4linked and bagged rear end with auto height adjuster and dump valve, water/**** injection, strobes out the waazoo (thats the short list)
Josh Carmack
Ripley, TN
BONE STOCK 91 F-350 CCSRW repair or restore paint, seats, radio, and all, to factory original then swap in a ZF-6 with an over/under Add pto or belt driven hyd. pump with a dump bed kit. Add exhaust brakes and a banks turbo drop down 5 wheel or bed ball and thats it I guess, I'm a fan of bone stock trucks restored to as much like their showroom sales days.
opusd2
BFE, WI
I want something that runs and doesn't look like it rolled end for end down Pike's Peak
mohavewolfpup
Diesel Wolf Puppy
Las Vegas Nevada
I'd pretty much keep mine bone stock and rebuild it bumper to bumper with all the known fixes. Maybe play around with a slightly more powerful turbo.
i like what i've done with the Nostromo and the Sulaco. the specs are down on my sig line. if I was to redo something it would prolly be a cab in better condition.
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
Truck one -
1997 F-350, 7.3L PSD, black, crew cab long bed, 4x4 with PMF 2.5" RSK, superduty front and rear leafs, traction bars, Bilstiens @ all 4 corners, e-350 rear disc conversion(keep the 10.25 rear end), hydroboost, BTS built E4OD with an aftermarket TCM, intercooler(not sure what cooler), T4 turbo kit(no idea what turbo lol) ceramic coat bunch 'o stuff, e-fuel, injectors, custom tunes, Isspro factory match gauges(lots of them, 4 on the a-pillar, then 3 above the mirror), factory alcoa's wrapped with either Nitto trail grapplers or terra grapplers(35's), probly do some sound deadener in the cab, 5 inch stainless(not the cheap crap either) straight pipe factory routing, 6 inch polished stainless tip, 4 rigid industries LED fog lights in the front bumper cut-outs(2 of them white and 2 amber for snow/fog, if they come in amber, not sure on that lol), not sure if i would get new amber bumper lights or go with diamond clears, fo sho be goin' with some true projector HID's for the headlights.
I would have this guy do my paint job for me.........
Finally a sunny day around here. This is the payoff for taking my sweet ass time.
Reflection in the rear door
A little better shot of the clarity
That's about it for truck one.
Truck two -
1979 F-350, 4x4, super cab long bed, 6.0L PSD, something in the area of 190/100 injectors, diesel site HPOP, DIY fuel system, sump in the fuel tank, Mad Turbo Werks turbo(not sure what one, they are coming out with quite a few right now that all work), BPD remote oil cooler, EGR delete, ceramic coat everything from the exhaust manis to the down pipe, intake mani, exh manis, 4"DP-5" stainless straight pipe factory route, 6 inch stainless tip, traction bars rear, '05+ super duty axles frt/rear, 4 link in the front, air bags in the rear, bilstiens, ARP studs, factory Ford gaskets, Isspro Ev2's out the wazzoo in a custom dash/gauge cluster, SCT programmer with some custom tunes, probly go with super ***** dropper(best name for a tune ever btw) from truck source diesel, looney wild from quick tricks, this one would be black as well. i'd figure out a way to do projector HID's for head lights as well. around 600whp would be nice.
Well.........that's about it guys, nothin' too crazy or too over the edge.
