Dreaded Code 62
hadley000
Upstate NY
The TCM can command lock up in 2nd gear. This is a normal function.
Interesting, I thought it only locked up in overdrive. I learn something new everyday. I have a new solenoid pack installed but the plug was wrong so I had to order a new one. The magnet had very little fuzz on it, but i did change the fluid and filter less than 15,000 miles ago when I had to change the broken 1-2 accumulator spring. I checked all of the valve body bolts and they were tight.
hadley000
Upstate NY
Still getting 62 after changing trans connector, FIPL, and solenoid pack, but now it's not slamming into gear when in limp mode and seems to be shifting through all gears. Why would it do this?
kbeck
