Door Cards Crew cab vs...?
itsacrazyasian
residentcrazyasian
boca raton, fl
Is the left front (drivers) door card different then say a 2 door truck or bronco? I found a new set of door cards that are $$$ but i swear the control plate looks bigger on my truck. No power mirrors on mine just the unlock/lock and the 4 window controls.
94f450sd
somewhere,ma
what do you mean by "door card"?92-94 door panels are the same for all cabs.95-97 crews have all 4 power windows with 4 window switches on the drivers door and are hard to find in salvage yards.took me 5 years to find one for my 95.found 1 3 days ago and grabbed it before anybody else got to the truck.
itsacrazyasian
residentcrazyasian
boca raton, fl
Yea thats what i was afraid of, mine has 4 door power windows. I swore it looked different compared to the non 4 door trucks. Glad i didn't drop the coin on it then.
Now i gotta find a good door panel for my truck.
93cc7.3
needs turbo power
plainfield IN
the only difference should be the switch panel not the rest of the door panel ,,,,, that switch panel has to come off separate from the door panel when being removed so you should be able to put the 4 switch panel on any door panel .... unless FORD redid their door panels just for crew cab trucks will all power windows to add 2 switches .... seems unlikely
94f450sd
somewhere,ma
that section of the door panel can be changed though.that piece had pins that poked through the panel and then were melted to form a "rivet head" to keep it together.you can change it by grinding the heads off and then remelting them.but i would have to imagine he needs a door panel due to that piece being broken and the window switches are flopping in the breeze like mine did.
itsacrazyasian
residentcrazyasian
boca raton, fl
exactly what i have. My problem is the previous owner laid tweed over the door panel and painted the trim piece blue and the bracket where the screws go to hold down the plate are broken.
I wanted new panels.
