...Why do they still sell the junk then?...
Good question. They are made for 6 volts in a 12 volt starting system to heat up faster. ****** idea if you ask me.
Since I've had my diesel for nearly 3 years now, I've gone through 24 GP's. They just fail sometimes, no swelling, just not working anymore. Then some swell, or break off, or develope growths (kind of like swelling, but more like a pen tip on the side of the plug formation).
I've even burned out a set of 10.5 volt rated plugs. I'm not running berus at the moment because I'm caught up in my own solution, but I hear good things about them. Just be carefull with the manual switch going to the Autolights or the Motorcrafts, because the beru's will still fail if left on too long.
If for some reason you are unable to get good plugs, this is the route I would take...Take the plugs out of the truck and ohm them, any that are .5 ish ohms or greater should be replaced with the same plugs. Then hook up to the momentary switch. This is where you have to be careful. Don't hook up the switch and have the controller working at the same time if you're running Autolights because you need to be in control at all times. When It's cold out give the plugs a few cycles of 5 second bursts. See if she starts. If not, then do more cycles, allowing like 10 second cool-down periods inbetween burns. All you're trying to do is get some heat into the cylinders w/o doing it in one long cycle.
