FarmerFrank
So I just stuck my new (to me) Doug Nash dne2 gear box in today. It's an overdrive model with a pto cover on the drivers side. It was a direct bolt in. I even dug through my pile of random driveshafts and found one that was 1/4" too short but worked perfect.
After I took it for a test drive I thought I better check the oil in it, and of course it was low. Luckily it came with the book and it says to use 80/90 synthetic gear oil. Even luckier I had some 75/90 synthetic.
When I drained the old oil out I would bet a paycheck it was ATF some one had in there.
I replaced it with the gear oil I had but then I got curious if these boxes were like the old 4 speeds that don't care as long as its oil.
So what are you guys with the us gear boxes running for oil??
