royzell
I think you may get another shot at it. In my neighborhood $2K for that truck won't sell soon. $500-$1000 for a parts truck is more in line.
Measure the widths of the springs on the rear. I put an 85 F350 cab and chassis rear end under my 87 F250. The tell tale signs are the 85 had like 11 leaf 2.5 inch wide springs while the 87 had 3 inch wide springs. The issue also is that the leaf spring perches on the axle are narrower. The 85 was like 36 inches and the 87 was 38+ inches. I just cut the spring perches off and welded them where they needed to be, but if your not into ACCURATE fabrication, this could be difficult. My neighbor has a frame rack and I was able to have a good flat surface to weld them on so accurate measurements were easily obtained.
