turfblazer
i own a 2008 rv with a cummins 400hp isl i believe its considered haveing a common rail fuel system and a (dpf) diesel particulate filter
i was 1st considering going bio-diesel i'm canceling that idea cause to many issues to get wvo on the road and processing it with the chemicals
i figure its gonna be easier to get wmo and wvo unprosessed! any thoughts ?
i'm planning on getting a good industrial centrifuge instead of the little 1/2 qt ones powered by hydraulics and putting that in my trailer to clean the oil
the real question is that can wmo be used in this unit as long as i do the preheating like you do with wvo
and possibly use either as a fuel or even mix them together with some diesel fuel and what % can i go up to
i figure i'll only use the alt fuel on the highway and not in the city i want good combustion without the ash formulation with slow driveing
i filter down diesel fuel to 2 micron now and i hear centrifuges if done correctly clean down to less then 1/10th of a micron
what to you smart guys think please no opinions from guys that are guessing i need professional imput !!!
i've been a gas mechanic for 40 years and some 20 with diesel but never thought of doing this before. now that i'm retired i can do what i want and that is to travel as much as possible without the fuel cost going into arab pockets and taxes going to the feds, we pay too much for fuel !!!
i built from scratch 2 wmo furnances 1 a boiler thats outside the house for the home and the second thats a combo hot air/ radiant for the garage thats inside you can't smell it at all !! the garage unit gets 45hrs out of 1 gallon of wmo with no visible exhaust except heat waves
reason i'm noteing my wmo heaters is so that whoever answers me has a good idea i have some experience in wmo and i want good advice on my next project my 300k rv and i don;t want to screw it up i want it to be perfect as i can be !!! this common rail system is new to me and the dpf might just have to be lost !
thank all you guys for the great reading a lot of your ideas have gave me other ideas and i thank your forum greatly !!!!!!!!!
turfblazer western ny
