6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
I have a crank case evac running into the exhaust stream in my moms 94 CC, the one with the "new 6.9", and it apparently is no longer working. It has so much blow by its insane in the first place. But I pulled the dip stick the other day when it was good and warm, smoke just plumed out of it, but when I revved the engine up above 1200 rpm it didnt dissipate at all.
The tube running to the check valve in the exhaust is attached to the CDR valve on the valve cover, Im guessing one of those valves has failed. And the CDR is brand new, less than 5k on it.
What do you guys think's wrong with it? Especially the ones running this system.
