Goofyexponent
Mentally Unstable..
Over the past 3 weeks I have niticed a little shudder in the truck when the torque converter locks up. I KNOW it's TC related because when I engage the 4 ways or touch the brakes the shudder goes away. Let the TC lockup again and it comes back. Only did it while cold though, once she warmed up to operating temp. she was fine...no more shudder.
Now, the front seal in the transmission has a slow but steady leak, but the fluid never got low enough to where I would say it was too low to drive....always at the lowest point on the stick, so I didn't run her dry!!!
Tonight, while climbing the ONLY hill on my run home I noticed a shudder ....while warmed up. It's not really a violent thing, just REALLY noticable.
I don't have or want to spend $1500 on a new TC and trans right now....if I had to spend that coin I would want to switch to a ZF and be done with that slushbox.
Is there anything I can do to check to make sure that it is the TC barfing it's guts? The fluid is still clean and not burnt..and I want to keep it that way. If it is teh TC, where should I buy one and what should I do while the trans is on the floor of teh garage when I pull her...
I just spent $2000 on this truck (tires, coolant, thermostat, ball joints, tie rods, wheel bearings, seals, rearend fluid for both ends, transfer case and transmission fluid that needs to be changed still, front end alignment, all needed bodywork and bought all the paint and guns to paint her), so I am not gonna let her go to another home....I'll park her and save for a built E4OD or a ZF before I sell her.
The ungodly amount of labor to R&R the trans doesn't change but the rebuild cost is avoided for a little while. It's a gamble, but if that's all you have is a lockup shudder, this might work for you. Cost of a HD billet cover convertor...$300 labor...$400 fluid...$100. that should be what a local shop to you should be charging to do the job. Warranty? forget it. That's not happening.
