Coolant filter anyone?
RLDSL
Diesel fuel abuser
Arkansas
$110 for a $15 filter head and a handful of fittings and two valves :eek: I wonder what he's been smoking?
Do a search here on the site, a number of folks have done custom installations and you can do it for a whole lot less than that.
88beast
pa
ya i was going to do it but i used the filter head for a wmo setup
but im going to get a new one and set it up
also always use a bypass in the setup that way if the filter clogs really bad the heat still works
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
Then there is the Teflon tape to consider as well,....;Really
damac
sacramento, CA
I made a coolant filter out of some cheap head I found on amazon that uses a ph8 fram filter. But I didn't think ahead as to the placement of the fittings. Mine had 2 outlets up top next to each other so I had to add a riser to one side and it made my whole setup way uglier and bulkier than it needed to be with black pipe fittings. It was cheap in that I got the whole kit up and running with a filter for around $50, but I also had to weld up some metal brackets that I bolted off of the fuel filter mount.
Not a big deal but if I was doing it over I think I would go with the typical mod with the napa kit others have posted about. Cheaper than that ebay kit but maybe a bit more than mine.
As far as performance on mine, I got my truck with a blown oil cooler. So I resealed that, got new lines, new thermostat and water pump to start fresh and installed the filter setup. It went through a couple filters in short order while I tried to flush the system out. Must have done a dozen cycles after I put acid in the radiator for a few hours. I used dishwashing soap that doesn't sud, calgon, and some over the counter products.
Finally just a few short weeks ago I started fresh with coolant and a new filter and I like what I see so far. Clean coolant and just a hint of something in the reservoir which could possibly be from me not cleaning it as well as I should have.
I couldn't believe how dirty the water pump area was when I pulled mine apart. Tons of gunk around there and red rtv chunks in the system? I wonder if that could have been original.
