clutch master cyl or slave cylinder
86truckpull
ct
hi my idi i pick up has no clutch peddle goes to the floor is there a way i can find out if its the master or the slave cylinder
lotzagoodstuff
Carmel, IN
Did you check the fluid in the master cylinder yet? Start there, see what the level/condition of the fluid is there.
86truckpull
ct
fluid is full andclear the master looks newer havent looked under it to see the slave
lotzagoodstuff
Carmel, IN
Maybe lots of air in it, I would try to crack the bleeders and see what comes out.
Good luck
johnnyb1
Zebulon,NC
My slave went bad once. Installed a new one,bled it. Worked great for 3 hours. Then the master went bad. Couldn't handle the pressure I guess. If one is bad just be ready to change both. I hope not because they sure don't give those away. They were the original ones in my '88 and had 250,000 on them so I couldn't complain. Except that it was the same day.:***:
