FordGuy100
It's a little late to mention this, but check how far the slave moves when the pedal is fully pushed in. It should move 3/4" or so (Mel what is the figure?). It's easy to verify if the master/slave is working before tearing into parts that may or may not be the problem.
Bleeding is a challenge! Ideally you would have the nose of the truck up so the allen is higher than the rest of the slave. You can actually bleed it your self by first filling the master (duh, make sure the little rubber flap came out with the cap), then using a pry bar to push the throw out bearing arm against the slave while loosening the allen with your other hand. It's a little tricky, but easier than trying to get the slave back into it's bracket with out the little plastic doodle.
I would also mention that a good diagnostic is that you shouldn't have any problems shifting gears with the motor turned off. If it's still stuck in 1st, or what ever gear when the engine is off, you probably have a mechanical problem with the transmission. In which case I recomend a ZF! Ha! Good luck.
No, its shifts out into and out of the gears easy now with the truck off, and yes I want a ZF really badly but it'll have to wait. So its not like bleeding the brakes where you have to pump the peddle a bunch of times to get all the air out? I thought that is how you would do it.
