clutch heim joint
no mufflers
rhode island
I am looking to do this mod on a customers truck. I know there are several threads on this upgrade. I am just asking if anyone can post a link to some of the threads.
the truck I am doing this on is a 1995 f150 with a zf 4bt.
one other thing is, I have bled the clutch master a lot. I will post some pictures and the one with the screw driver in it can someone tell me if the compression of the cylinder looks good enough.
no mufflers
rhode island
thanks for the links guys. ;Sweet
new problem, now that I have everything back together and can use the clutch pedal I cant get any pedal pressure. I bled the master separate and it seemed to be working fine. when the pedal is being depressed the slave makes a hissing sound and barely any pressure comes out of the bleeder. does this mean the slave is bad or something else.
usually have my son push and keep the pedal in while I bust open the bleeder. several times
