Changing Fluid in my Dana 50 TTB (IFS)
WhiskeyBottle2
TX
Hey Guys...I went to change my gear oil in my front axle. It is a Dana 50 TTB (IFS). How do I drain it?
Do I use a suction gun or drill a half inch hole and tap it for a plug? I can't seem to find a drain plug...only a fill plug..
Thanks
Thanks
You ANSWERED your own question...
NO drain plug...
Suck it out
Drill out a hole tap it and then plug it..
remove axles completely and then unbolt it...have it pour out then while out drill tap clean it all out
Assemble and install new seals and ujoints for good measure...
War Wagon
Terry, MT
I prefer the "pump it out" "suck it out" it's not that bad to do. It's the quickest and easiest.
Yeah I decided not to drill...I bought a nice little gear oil vacuum pump from Northern Tool last night...Check it out...
http://www.northerntool.com/shop/tools/product_200475124_200475124 It is inexpensive, but it will work!:sly
Lock your hubs in...leave truck in 2WD on transfer case...drive a good long ways...heats up oil in front diff...won't hurt anything in transfer case cause your in 2wd...
When you get home....pop the plug and drain away...warm gear oil is so much easier to draw out than cold gear oil IMHO
As for that suckeroutterthingamajiggy I don't know if that tubing can pass thick gear oil even if warm.
JM2CW
Al
WhiskeyBottle2
TX
Warming thr gear oil
JM2CW
Al
Thanks for the tip on warming the gear oil...As far as the "suckeroutterthingamajiggy" goes...It should work, but if it don't I will figure out a way to make it work...If I can't I will either "drop kick" it back to Northern Tool and get my Ten Bucks Back! LOL
Other option....getter good n warm...come home putsmall camp stove under diff...getter good n hot...thin oil out....naw...don't do that...was total joke..tongue in cheek!
Ya I tend to like the more HD suckeroutterthingamajiggies....this is one I have ooodles of experience with, as it's what I used to suck out lots of transmissions tcases, some diffs and so forth processing vehicles for crush....they have a pneumatic version too...
This bad boy here...is on my Christmas wish list...total suckeroutterthingamajiggydohickypumperbackintoo LOL
Then I do a tad more n just the occasional diff ....so I'd like to use this ....can even be used to bleed brakes if you ad an optional kit...hell ya I will! all four bleed screws at once...hmmm..stand and fill master....ya
olsen726
