xpbprox
If you don't want to read all of it just SKIP to the last 2 paragraphs
So I bought this 85 diesel a little while ago and I haven't been able to get it started. Story is that I bought it from a guy who bought it from a guy who was in the middle of swapping in a 7.3 from a 92. Got it wth the ip and injector lines just loosely placed on top of the black, everything else was hooked up but the ip and the injector lines. Well I had a hell of a time figuring out how to actually place the ip gear as everything was lose. I finally got the Y's lined up. hooked everything up truck didn't start. Didn't know what I was looking at so i blindly bought some used "working" injectors. After cracking one of my old ones and one of the working ones, I could clearly tell the difference that the injector's nozzle was actually rusted to the the nozzle housing. So my old ones were shot!
Installed new ones, tried to start again.....NOTHING. Now this time I learned that you're supposed to bleed the lines by cracking them open at the injector. I couldn't get and fuel to bleed out. (TURNS OUT THERE WASN'T ANY) but didn't find that out till later.
So blindly again I went and bought a used IP, installed it. Tried to start again, nothing. So this time I decided to completely disconnected one of the injector lines to see if fuel was even coming out. Didn't see any fuel, maybe a little drip here and there. So here's where I'm at. Lift pump has not been tested for pressure but when I install the IP completely dry, it gets filled up. I can tell because I removed the top cover and it full of fuel. I understand that the FSS had to be installed correctly which I believe I have been doing. My whole engine harness does not work so I got it rigged with some romex straight the the battery when I'm trying to start.
So I guess my question is could I have possibly just have had 2 bad IPs or what? I'm thinking I need to run some ATF through the new used one I just put on. I actually went to the junkyard to pick this one up and saw the guy remove it off of a complete 6.9 block. So maybe because it had a bad IP is how it got there in the 1st place or it's just sticky from the time it's been sitting. I took the fuel screw plate off and I could see the shaft rotate. Any ideas?
