Sorro71
My Truck has developed a shudder in 2nd & 3rd gear when I'm coasting
It only happens when it gets up to operating temperature
When its cold it shifts hard and then when its hot it seems to shift softly so much so that when my speed is 40 to 60 km/h and I'm not on the throttle much it drops back to second very easily where I almost cant feel when it changes.
A bit of history
The transmission is about 2 years old since it was supposedly rebuilt, it was an exchange box. Its only done about 10000 kilometres. I first ran a dexron 3 oil in it, I'm pretty sure it was called something like texamatic 1888. Since my engine rebuild last year I have run a synthetic oil in it which is supposed to be compatible
I've had a couple of leaks that I've been able to fix, the selector shaft seals and around the band adjustment nut was leaking. I was able to squirt a little RTV behind the nut without moving the adjustment. I drove it for a couple of hours after the repairs and everything was fine.
The truck has then sat for at least 2 or more weeks. Now when I drove it yesterday it has started to shudder.
I've checked the oil level and that is ok.
Any ideas on where I should start the process of elimination to try and find the problem?
A bit of history
