I cant read the code on the second, but that 41 m1 is OLD! , that critter could be anywhere from late 30s to late 40s manufacture. Nothing wrong with it they were built like tanks. The gear ratios on the 41 are a bit different than what you would find on most 3 speed brownies as it doesnt have a deep reduction Under drive, it has what is calld a medium low that allows you to evenly split the brownie, 1-2-3, then shift the main box instead of 2-3 then the main on a regular 3 speed brownie with a deep reduction, but you do not have the advantage of the extra crawler range for heavy pulling, you just get one gear below first, but you do get the ability to split each gear three ways instead of just two which would give you immense flexibility in the mountains with a heavy load as you would only have to let fall about 200 rpms and you could drop another partial gear to keep the engine in its power range
I do have some partial specs on that box
