BigRigTech
Diesel junky
I've been having a brake issue on and off with my 91. Sometimes when I stop at a light the pedal seems to creep very very slowly, not to the floor but it creeps enough that you can feel it. I've replaced the master cylinder and bled the entire system twice....Here's the wierd part - if you put your foot on the pedal with the engine shut off it's rock hard and stays that way....????
The master cylinder and rear wheel cylinders are off my 96 1-ton parts rig. The W/C's have a bigger bore than the ones I took off but they bolted up ok. I installed them today along with replacing the brake lines on the rear axle. I ran out of time this morning so I have to adjust them up and test everything tommorow or Monday.
