boost psi
Steve Kelton
Highpoint NC
Installed Edge evo. Only getting 1 to 5 psi on guage. Ideas.. Truck runs great Stock 99 F250 7.3.
Diesel JD
Gainesville, FL
What turbo and truck? Fuel turned up? Exhaust and intake mods. Might be normal, might be a little low, we'll have to have more info. My truck, 6.9 2wd auto, ATS non gated turbo never sees any boost until around 2000 RPMs or under hard acceleration/big load. Its usually boosting 0-1 psi cruisiong on the highway, 2 empty under hard acceleration maybe 4-6 with a cord of firewood or if I really stomp it.
subway
be nice to the admin :D
York PA
chips are for dipping LOL
just some friendly ribbing sounds like you need the powerstroke section
did you get good boost numbers before?
FordGuy100
Silverton, OR
If your truck is running great, and has good power, then I would say that your reader is reading it wrong. A PSD running those boost number will be a dog, and EGT's will get crazy high fast. Plus it would smoke like a freight train (is it?).
Steve Kelton
Highpoint NC
no smoke
Steve Kelton
Highpoint NC
F250 99 Edge Evo
what are the details on your truck? fill out your signature.
woops my bad just saw you edited your post. i'm with fordguy, has to be reading wrong.
If you look at Diesel JD he has the same issue. The edge is getting its boost reading from the trucks computer. How can it get an accurate reading.
FordGuy100
Silverton, OR
You cant compare an IDI's boost pressures with that of a PSD. PSD's have lower compression ratio's, so they run more boost. But with an IDI we run less boost (generally 12psi max is the accepted value) because we have much higher compression ratio. Your truck should be in the low to mid 20's for boost.
Diesel JD
Gainesville, FL
Yeah I thought he had an IDI at first. I think if truly a SD with a powertsroke only had 5 psi of boost at anything much above idle, power would suffer and you'd have a crapload of smoke. I'm pretty happy with 1-2psi around town in the IDI, believe me it can build more boost when I really need it.
