body mounts
HammerDown
Glenolden Pa
Well it's alot easier with no carpet for sure...
If you remove the seat n carpet you can give a quick clean of floor etc too ;)
Two bolts under the front angle upwards in the foot well one in each corner
and then two behind the seat near the rear cab wall under a plastic cover/grommet
As for lube...not sure...lol
That's where my drivers side floor is rotted and separated badly:puke:
Optikalillushun
Coal Region, Pa
I dont think i used any either, i just slide em in dry...wait wrong topic.
seriously though i dont remember if i had any when i did body mounts but im thinking i didnt.
jonathan
sullivan In
Ok cool. Just about got the front seat out just need to un bolt the seat belts my help had to go to work aka the wife lol
jonathan
sullivan In
I would suggest to take car seats and trash out before pulling the the seat out. Mine was sorta clean except few monster cans and some empty packs of cigarettes
jonathan
sullivan In
Riot your right I said it wrong lol. Heath thanks for links I'll see if they ship it here before Sunday. If not I'm going install them dry because I took some vacation time to do this so time is limited
While on this subject...
On the core support mounts, does the bolt thread into the washer looking thing that's up against the bottom of the core?
(Bolt heads snapped off)
Thanks. I tried heat and chisel with sledge, didn't budge it. But I didn't try the simple thing of twisting it. Lol
The problem is for the radiator core mounts, is all road salt, battery acid, and everything else gets in there and can't drain out.
jonathan
sullivan In
Well i got the seats and carpet out and put front seat back in. That I can still drive it. Jasper it looked like a normal bolt. On a side note my core support is rusted out. Looks like I'll be looking for a 86 model one but that's another project.
Optikalillushun
Coal Region, Pa
IIRC, there is a nut, allignment washer and larger washer on the top side and from underneath the bolt does thread into sleeve. I would (which i shoulda done) cut the bolt below the sleeve i didnt and it took me an hr each becaause i thought i could save them and reuse.
this for a bronco but its basically the same: http://www.supermotors.net/getfile/194329/original/body-mounts.jpg
Body / cab/ box mounts are rarely if ever easy to remove and don't for the most part come apart properlly.
TORCH is your friend here....
Have fun good luck....
jonathan
sullivan In
I got one mount out!!!! It took a few minutes to drop the tank and making a puller. I'll try to post some eye candy later....its bed time. I'm really sleepy
Staff online
