GREASE FIRE
if my truck sits for more than a day or two it needs to be put on a charger to get it started, otherwise it just barely turns over. Once it starts i can drive for a while & shut it down, then it will restart just fine. I stopped by an autozone and they put their battery tester on each battery and said they were both good - i asked if it matters that both batteries are connected to each other when testing them and the guy said no. It seems to me you would have to disconnect them and test one at a time....
the alternator says "reconditioned" and is a 100 amp and looks newish so i don't think that is the problem.
basically i am just trying to figure out if the batteries really need replacing before buying new ones. Any advice? i just don't get the part about why they would work fine but then after a couple days be dead. It almost seems like the lights were left on or something - but i know they were not, nor was the cab light.
thanks,
Paul
thanks,
Paul
