I was just wondering what you guys run for oil pressures (idle, high rpm), EGT (idle, shutdown temp after a hard run, highway at 75, highest it's ever been), and boost pressure (highway at 75, max pressure). My oil pressure runs 40 at idle, 50 at around 2500. My EGTs are 270 at idle, shut it down below 350, around 650 on the highway at 75, and the highest it's ever been is 1500+ (my pyro only goes to 1500). Boost runs 12 psi at 75, and max is 40. I'm just curious to hear this stuff, so if there's anything else you want to throw in be my guest.
