Axle Ratio
Rock
Tunkhannock, PA
Hello everyone I have an 84 F250. The code on the door says axle code 73 can someone tell me what gear ratio that is?
jam0o0
houston, tx
crawl under the truck. on the dif there should be a metal tag under one of the cover bolts. on that tag it will have 3.31, 3.55, 3.73, or 4.10 along with a bunch of other gibberish. if the tag is gone there could be anything in it.
jam0o0
houston, tx
^than list doesn't have the right info. it says 73 is a d80 with 5.13 gears in '91.
bike-maker
albany, OR
IIRC factory rear end that came behind a diesel should have been a Dana 70. Only the gassers had Dana 60's.
