ardunio madness
1mouse3
il
Well, I got it apart...
And this was a, mostly full spool...
That gave me a spagety mess of wire...
That gets preped for pins...
Oh wait, was cattywampus and now its fixed...
Now to pin the wires, I had to change the setting softer on it...
This should stuff together...
No, what about this way. That took a bit of poking...
No, again. Well after jiggling the first for a few hours, it sliped toghter. The second way, damaged a wire that had to be replaced.
Now its this side turn, but not today.
@Dirtleg! I have a road map to where were goin right now.
1mouse3
il
@1mouse3 What bulkhead connector is that, or what did it come off of? Looks perfect for the harness I am redoing.
This is a standard female
This is the bulkhead female
This is the male
In the pdf, part number for pins can be found. As for the crimp tool, It took too long to get. Those are E key and there is A-E for choice, as in 18SE need changed to 18SA for A key.
edit: looked around found a cheap crimp tool not shiped from china, like the the one I got.
1mouse3
il
Well got the other side pinned...
Then I lightly twisted the digital sensors...
Now its repining the plug and being annoyed at the fight...
Now to twist the floating ground around the picky ones...
These could work in a perfect world but Im not playing there game of chase the loose conection...
This is a joke of a tool, had to be filed and is flimsy...
Now I can tether this black box to the firewall...
Then needs to find mount round here...
Then down yander...
I might find light at the end of the tunnel...
And emurge here, where need to make a panel for it to mount.
1mouse3
il
The harnes I made on the engine was nice and neat, but some wires where scrambled that had to get sorted...
This is where and how it pokes through the fire wall
So got the magic window to cough up some info...
This atmel box, comes with this software that gives some the stuff to do calibrations of sensors...
The hotest place I could aim this, is down this hole...
So starting with the temp, I get this as what needs converted. That temp is still off, the fan switch is on low and is unpluged, so will stay somewhat stable to get both readings. So think just raise both temps by 10, and see where that gose. Issue here is I got volts and not ohms, need to find that to continue with this one
Code:
vref - 5.32
-after a drive
3.26v
163*F
-after some sitting
4.57v
96*F
-fan switch
61318361787
low - 180*F
high - 195*F
