ardunio madness
1mouse3
il
This is the latest thing I’m working on that will replace the instrument cluster, 7” touch display, I’m not much of a graphics designer so it’s a bit on the blah non flashy side but has everything that’s needed. Life has been a bit busy these last few years so progress has been slow.
This is interesesting, I ran across one that has interesting guage lay outs if you where looking for ideals on gauge types on the display.
1mouse3
il
I got some sensors...
These are...
EGT from a Dmax
EGR EBP form a 6.0 psd
Intake temp form a 5.9
Map from a 5.9 or psd
oil pressure form 8.1 bbc
1mouse3
il
Went to the yard to go hunting for stuff to wire this lab rat...
But came up short on plugs and store had one in stock, so waiting on that. Probably should had stripped a harnnes for wire but did not have time for that.
That looks like an old vw over the battery fuse box. Surprised the alternator circuit isn't melted.
1mouse3
il
You win, a grid heater with some amps will have a shot at melting it and replacements are easy to find.
What's really funny is you can still by them new. I still have a few lying around from my old vw days, never thought to use it somewhere else... I smell samurai adventures...
1mouse3
il
Lab rat lives matter...
:joker:
It did grow some ears, I ran out of splices getting up to them
Time will tell if two spools is enough.
And cant give a part number for this 1/8 to 1/4 adapter that came with one my blocks, just that emd is stamped on it and need to tee off it.
1mouse3
il
I had to declare open sesame, so can get splices I can crimp.
So now the engine side of the harness is for the most part done. Need to see if can get tesa tape local, other wise will deal with a sticky harness.
This is getting left so future me dose not pull his hair out to service this.
1mouse3
il
So close. Are we there yet?
Not yet, need to finish running around in a circle with my tail cut off. It could slow and maybe stead, right now trying to finish fixing the cab mount befour I throw that engine in. I want that in place first, so that the harness is sized right.
