air in fuel
genchowford
genchowford
Texan by the grace of God
92 f350 7.3, every so often have to bleed the schrader valve, has holley blue mounted just after the pollack, mechanical pump disabled, have checked all the connections. any help would be appreciated.
thanks
Fred
Exekiel69
Do You still use the clip connectors for the fuel tank selector and fuel pickup and return? This use a o-ring and if not replaced it can leak.
