Air Filter Wrong???
triplethreat
AGENT ORANGE
Hubert, NC
I just got my filter from Filter1 today and I coud have sworn it was supposed to be round not oval (the trucks not here to check) anyway there is also a tab broken off although the pic is blurry. Can you guys tell me if it's the right filter or not.
Dan
triplethreat
AGENT ORANGE
Hubert, NC
I don't know if you can tell but in the last two pics one of the little tabs is broke off do you think it would be a problem to still use it. I'd hat to send it back. I always thought the filter box looked round not oval.
Dan
timntools
Chief Runinscissors
Hendersonville, TN (Nashville)
no, its oval. and as far as the tab, I'll prolly break mine off the next one just to make install and removal easier. (if I finally keep a truck long enough to have to change the filter...let alone oil...) LOL
seagravedriver
Puyallup WA
Looks like just what I got, & my buddy. His fit. I have yet to get anything wrong from Filter one. Craig
seagravedriver
Puyallup WA
But mine did not have that orange/yellow furry thing stuck to it. You didnt try to install it with that in place, did you? ;) Craig
triplethreat
AGENT ORANGE
Hubert, NC
No, It is the right one had no problem putting it in took about 15 minutes and no cuts or scrapes.
Dan
swanee
Fillmore, CA
Was that the open air side or the engine side with the broken tab? If it's the engine side, I'd be leery of using it. I think the sealing on that side is questionable at best, and with one less working clip, you'd just be asking for trouble. JMHO.
triplethreat
AGENT ORANGE
Hubert, NC
It is the engine side but, there was enough of it left that it did seal quite well. I took the whole section out and put it together where i could see it and there is still enough of the tab there to seal it.
Dan
Bear Hunter
RLTW!
Well....I hope you sent it back and got one with the "tabs" that are intact. Those tabs are used to secure the bottom portion of the filter (there are no metal clips on the bottom like there are on the top)...and the pic you are showing happens to be on the turbo side...so unless you want dirt getting into your system...breaking off tabs for easier removal is definately not a good idea.
Bear Hunter
RLTW!
...or are you talking about the top of the filter housing? Its hard to tell from the pics...either way, you paid good money and should get what you bought undamaged.
JohnSWA
I'm curious about what you paid for it from filter one. Yeah, I know I could go check myself. Maybe I will. I bought mine from Walmart! Yup! They have them there! I think I paid $64 or something around there. At first it looked like a daunting task, but after loosening the two clamps on either side, it wasn't so bad.
Another thing. Does the freaking indicator work for you? :mad: I finally reached 34K and thought I'd change the filter anyway even though the indicator showed no problems! I live in a "high dust" area and can just imagine dealing with the service writer if my turbo is damaged because I relied on that stupid indicator!
Anyway, I thought I would throw in my 2 cents as well as a couple questions. I was really surprized to find both the air and oil filters at Wallyworld!
pwillis
