after market oil gauge where to tap into the motor
86F2506.9
6.9 International
Myerstown, PA
where is the best place for me to tap into a 7.3idi for an after market oil gauge turbo feed is goin right where the oil sending unit was
fastass350
SStock8569
Washougal, Wa
I think you can tap in on the lower left of the block, if there's room between your exhaust. All the way to the rear. Someone else should know better...
argve
Resident Fruitcake
Gwynneville, Indiana
Install a tee so that both the turbo feed and the pressure sender (switch) can see the oil pressure.
RLDSL
Diesel fuel abuser
Arkansas
Bump i cannot seem to find this or my temp sensor port?
The factory oil sender taps off the block at the top rear of teh block back at teh bellhousing . Right where the engine mounts to the tranny there is a sender sticking up for the oil pressure sender for teh factory gauge. If there's an ats kit it's already been adapted to an oil feed T there but you can easily adapt another T to tap another fitting for an extra gauge.
Another spot would be down on the drivers side of teh block there is a small pipe plug in teh area of the bell mounting again just aft of teh cooler that will take an 1/8" npt fitting( also a very good place to tap in a bypass filter)
there is also a large pipe plug on the cooler itself, but access stinks.
