ACCELERATOR CABLE QUESTIONS
MIDNIGHT RIDER
Lately, I have had my accelerator-cable to FREEZE, both in the driveway and going down the road, whenever the outside temperatures are below twenty-degrees.
After numerous attempts with heat-guns, WD-40, etc., and still having freeze-ups, I completely removed the cable from the truck and hung it up behind the good old sheet-iron stove, where it's about two-hundred degrees, give or take.
After a long hot hanging, I saturated the inner sleeve numerous times with WD-40.
Now, it is getting HOT machine-oil poured down through the insides, until it drips freely out the bottom end.
Now for my question.
Since I have the whole cable out, I have taken all the possible measurements and recorded them in my notes, for future reference.
While I was at it, I figured to also write in the correct part-numbers for a replacement, should I ever have cause to need that information.
The longest overall measurement of my factory-original cable is shy of 36" and it could stand to be a touch shorter.
All the replacement cables I have found are 42.625 long, much too long for my truck, without putting a loop or an ESS in it.
http://www.partsamerica.com/ProductList.aspx?parttype=656&ptset=A&searchfor=Accelerator+Cable
http://www.rockauto.com/catalog/racatalog.php
My truck is a manual transmission, 1985 F-350 Diesel.
What gives on the too long cables ??
Is the shorter one available anywhere ??
The one I have is fine, I just like to jump these kinds of hurdles before I run against them in a pinch.
Thanks.
diesel4me2
Camping is more importanter!
northern illinois
when i changed mine carquest had the most options avaiable in length 35 39 and 41. no parts on there web site, have to call them to get part numbers
chris
