A SHO fan fight
1mouse3
il
But I have not considered wire nuts and romex, as a option for my wiring and there may be confusion with me poking fun at my misery here...
"Beneath the smoo is surgery that was need, there was a loose nut job in there..."
When that is in reference to the smoo in the circle and vibration could had been cause, where this will need put in place of the decommissioned solenoid at some point...
I found a feral cat, so @Nero might be happy with me trying to resolve the above issue...
The 2ga lead to the 6g alternator and pass through, is fused and should fail if the fans deiced to find a short...
I made sure to have the need fusing in the cab for add on's and these the ones that want to pose for a pic...
There is proper rated pass through, so wires dont strip them self and cause a short...
But do need to put the reaming ferals on this power point at some time.
Those wiring jobs look pretty good. We use those terminal ends with screw clamps on generators at work, they sure are nice to have!
What I hate is the what appears rats nests of wires everywhere, like it was laid down and 'I'll deal with it later' kinda look.
The hot wire pass through and isolators, chefs kiss, looks perfect.
1mouse3
il
It is...
- Im charting uncharted waters with dual two stage fans, that floats the first stage on second and there is cascade of load to the switching side.
- So been doing upgrades to the fans as I go, where there is decommissioned tries still in place, did not do all wanted and the solid state relay is seeming to solve the cascade issue
- The is no proper place to have a added fuse panel in the cab, where will have to take a sharpie to mark the kick panel plastic that will be hiding those fuses
- Im using the smaller 2 channel amp instead the 4 channel, since had to use a cd changer with the radio but finally source out the rare mp3 adapter (want that 3way deck)
- So the desired amp can be mounted 90 degrades of the current used one, so can route the wiring better and will be changing speaker lay out after testing function
- Its set up as 4 way but will be making horn for mids to make it a 3 way, moving 1 channel to be power speakers for the second radio since have issues hearing it
- Where will add more midbass to give better output, but mean making new boxes and mounting them else where
- Not sure want small subs but have two matching amp for ocd reasons, if that is a option want
- Also still need to sort out the gauge panel that is not made correctly for resistance calibration, that is the reason for all the matching yellow wires above the pass throw point
I like what I have created but see changes that could make it better, where is a work in progress as get stuff and failers cause changes to be made.
