plywood
Recovered N/A
Sounds like you're on track.
If the switching valve was clogged it would start right away after switching back to the front tank.
If it takes a while to get it started again then you may be sucking air when switched to the rear tank, in which case, well the gauges often don't work right either, are you sure the rear has over 1/4 tank of fuel?
