83 F600
Magoo
Blind Brain Surgeon
Southern Oregon
Nieghbor has this truck, has 80k original on it. Has a DT466? Is that Detroit? Its a NA motor. Looks real clean. Asking 3800. Been out there a while. Has a 2 speed Eaton and a 5 speed.
I would like to make a work truck out of it. It sits low, has the 20 inch wheels with split rims, so I am thinking service bed, 22 inch alcoas beefier stance and a add on turbo if they can go that route.
nevrenufhp
torque ******
Sacramento
83.....I'd be thinking Cat 3208. But it's not a DT466. More likely a 6.6 or 7.8 (478ci)Ford New Holland, those came N/A I think, also. I'd pass, either engine isn't bad, but there's a little more to it than bolting up a turbo. If you go look at it, look on top of the valve cover, it'll tell you all you need(engine make, size, hp rating).
tractorman86
Buckeye, AZ
dt466 is an international, it might have a dt444 which is basically the same motor as the 7.3 idi
