IDI-IKE
I scooped up a 85 international s1654 with a 6.9 in it and a spicer 5 speed. I know it's not a ford idi but I'd rather post here that the medium duty forum because this post is mainly about idi engines. I have a January 1992 7.3 stripped down to the block on the stand one of the cleanest nicest looking idis I've taken apart. I also grabbed a Eaton Fuller RT613 13 speed transmission from a L9000 with a 3208 in it that I have the gears and related parts to convert it to a RTO613 overdrive unit. I'm gonna hop up the idi I've never actually done a mildish performance build on one my 84 has a studded NA with a almost maxed NA pump and a turbo engineering / rajay turbo kit on it moves along very well. On this NA 7.3 this is my plans for building
ARP head studs
R&D turbo cam
R&D 110 pump
R&D stage 1 sticks
Total seal rings
New bottom end bearings
Comp 910 springs
Water to air aftercooling
Borg s364 .091
Spoke with Justin about getting that stuff and he helped me choose that turbo if it's too laggy I can drop down on the turbine housing. He said with this setup i should be around 350/700 at the crank. Engine won't ever be lugged the truck has 5.82 gears but with overdrive and 42 inch rubber (11r22.5s) I'll be around 2700rpm at 70mph and I'll beable to keep the rpm up with the 13 speed because I'd imagine lugging with a 5 speed between gears built like that would kill it. Am I crazy? Should I be doing more supporting mods? Maybe I should be taming it down a little? I'm all ears I've been around these engines for over 10 years owned over half a dozen fords with theses engines. I plan on driving this truck from Wisconsin to Alaska at some point then back here to Wisconsin so I want it reliable. It's going to mainly be used for hauling my vintage J.I. Case tractors to shows and such. Thanks!
ARP head studs
R&D turbo cam
R&D 110 pump
R&D stage 1 sticks
Total seal rings
Comp 910 springs
Borg s364 .091
