Subject truck: 2002 F250 Powerstroke with 27K miles.
Need:
Rags
Pan
Plastic water bottle
fliter
socket set
strap wrench/channel locks/filter cover removal tool
1. Remove powerstroke plastic "thingie"
2. Use a strap wrench or channelocks to twist off the plastic filter cover. I used the fancy bling bling filter cover removal tool from dieselinnovations
3. Pull out the filter and rubber o ring and put the whole mess into a pan.
Tip 27K is a little too long for the filter...
4. New Racor filter F4596 from dieselinnovations for 18.44
5. Slip new round O ring around the base of the filter just like the old one.
6. Drain water seperator by placing a bottle over the drain on the passenger side of block.
The bottle I used was a little too tall to fit, so I poked a hole in the side
7. Drain the water seperator by turning the yellow valve to the right, then CLOSE the valve when the bowl is empty.
8. Lube the oring on the filter with some diesel and place into bowl snugly.
9. Lube the filter cover with diesel and place around the top of the bowl
10. Retighten filter cover
11. Reinstall powerstroke plastic "thingie"
Adrianspeeder
Need:
Rags
Pan
fliter
socket set
Adrianspeeder
