bluecollar
- Joined
- Jul 14, 2006
- Posts
- 33
- Reaction score
- 0
The drain valve at the bottom of my water separator has developed a nasty leak lately so I checked it out and now it's worse. There's a little nut on the inside that seems to hold a threaded brass fitting going through the bottom and I can't get this thing to stop leaking. Just my luck as I was trying to get that little nut loose I accidentaly bent the head of that little spring loaded (looks like a shrader valve) too. Can someone tell me my options here. Rebuildable, or buy the whole bowl from the dealer or maybe get a used one or what. When I put it back together I didn't see the little spring loaded valve leak but that drain valve is putting a steady stream out while truck is running.
