7.3 to 6.9
DaveBen
Ukiah, Ca
When you are trying to attach a picture you MUST go to ADVANCED and attach it there or it will not show up.
gird123
US
So with the little info i have given you is there any reason to keep the 7.3 and put the turbo and zf5 on it? I like that the 6.9 has been slightly rebuilt, and it will be out of the donor truck to install studs check all injectors...and my truck wont be down. Once it is finished I will have a much shorter down time.
Plowmaster
Upstate ny
Not really. I wouldn't. I'm actually in the process of building a 6.9 turbo to replace my 7.3 turbo
On edit, there are some larger internals in that turbo motor, but that wouldn't sway me away from a fresh 6.9, depending of course who put it together.....And studs are cheaper for the 6.9
