Here's some more questions for bbjordan. This is STRICTLY talking about non Factory Turbo engines. From what I understand, the flywheels/flexplates are completely interchangeable, right? Now if the balancer should stay with the crankshaft, then why shouldn't the flywheel/flexplate stay as well. If the balancer is balanced to the crank, then wouldn't the flywheel/flexplate be as well? Are the 6.9 and 7.3 flexplates for a C6 differently balanced? How about the dual mass flywheels? Are the ones for a 7.3 transmission and a 6.9 transmission different too? Yes I've seen two ZF5s in 6.9 trucks from the factory. You can tell because for some reason, the shifter isn't straight like the ones with a 7.3 are. They are curved similarly to, but not exactly the same as the shifters on the four speeds. How about someone who puts a ZF5 in their Bull Nose? Would you have a flywheel that shouldn't be used? If so, what flywheel should you use? What about a SMF conversion? Would that only be good to use behind a 7.3? Here's something else. Was there an option to have a four speed manual behind a 7.3? I know that gas engine trucks still had that potion until 91 or 92. If it was an option, would this have a different flywheel than the same transmission behind a 6.9? Now that you've pointed the differences to me, I'm really curious to find out more info.
