7.3 IDI intake heater...this weekends project
FarmerFrank
Blairsville, Pa
I might try to put it right in the intake since I'm rebuilding one right now. Maybe between the turbo and intake
FarmerFrank
Blairsville, Pa
I got a blown up 354 Perkins with that heater, could probably tie it into my fuel filter head for a supply. The wheels are turning now!
Michael Fowler
Bel Air, MD
Perkins uses an intake heater that blows a small flame to warm up the intake. I thought about one of these until I seen how much oil and crap is inside my intake... Probably wouldn't be the best idea.
My grandfather was an equipment operator in the strip mines most of his life and I remember him telling me in the winter they would let corn cobs soak in diesel all night. Come morning he would shove one in the intake and light it on fire. About the time you got the pony motor running the cob would almost be out so you started to turn over the big engine and it would suck in the smoke. Then the beast would come alive.
The cob would get that big intake warm enough to start those old brutes. Always found that neat
That brings back a memory!
About 40 years ago I was running a soil drilling operation. We shared a storage yard with a Excavation contracting company. They had some old Cat 621 pans with pony motors. One really cold morning, I was working on my rig, and watched the mechanics go to one cantankerous old 621, fill a drain pan with diesel, light it on fire and shove it under the oil pan of the cat. Then they went and drank coffee. They repeated this, and then fired up the pony, and had it running real good. But when they engaged it to crank over the Cat engine, it immediately died. They repeated the entire sequence all morning. It finally caught and ran about noon. They let it run another 3 hours before driving it into the (heated) shop to sit overnight so they could work on it the next day. I can still hear the pony motor running wide open, and quickly stalling as it tried to crank over that Cat with all that old, thick, COLD oil.
chris142
SoCal
prolly had sae40 in it!
War Wagon
Terry, MT
Very cool. I was really interested in how it would actually perform. That's good to hear that it works well.
Black dawg
sw mt
Have you got to try this out much more?
My trucks wont start in temps warmer than that, with a glow plug for each cylinder AND and intake heater.
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Put it all together this morning, -36c with no wind and the truck hadn't been plugged all night. I cycled the intake heater for 15 seconds and turned the key and pressed the starter button right away so the glows didn't have time to cycle and the truck fired up in 3 cranks....id say that is a huge success!!;Sweet;Really
We need a control for this little experiment. Gotta be able to measure the improvement (at least prove it to those of us that don't drive this truck daily).
Does this truck normally start well with just the glow plugs?
Will it start without the glow plugs?
FarmerFrank
Blairsville, Pa
so you are telling me that these trucks are supposed to start good in sub zero F degree temps?
My bad, You said warmer than that and i was assuming that you meant it starts better in the cold than it does in the warm telling me the IP head would be worn out... But you know what they say when you assume.
Black dawg
sw mt
no worries, my wording wasnt very clear.
TWeatherford
Flagstaff, AZ
I'd love to see a video of an IDI, or any diesel for that matter, fire up in a few revolutions at -36C (-32F), after sitting overnight with no block heater.
MadScientist
