7.3 idi engine 1989
Big Bart
Tow&Slow
Newport Beach, CA
Hard to say without questioning prior owner but some thoughts
1) As Nero suggested PO was not running diesel engine rated oil like Delo, Rotella, Delvac, Amsoil,etc. These are formulated with detergents to minimize that. Or waiting too long to change it.
2) Maybe the IP was turned way up to “roll coal” but was polluting the cylinders and gumming up the rings.
3) Maybe PO was running waste oil or home made bio fuel currently or in the past.
4) Maybe the engine sat for a long time and the rings got stuck. I have seen this on this site. Truck sat for years, now running, running a little rough or burning some oil. After a tank or two of good diesel, fresh oil, and some run time things free up.
5) Running too hot. Maybe prior owner did not have it timed, turned up fuel mixture on IP, or if turbocharged did not what his cylinder temps. Baked in oil, soot, and other contaminants from the diesel into the rings and grooves.
6) Maybe multiple of the above.
Again hard to say without knowing the history and being able ask questions about oil, oil change frequency, did they or the PO before them mess with the IP, did the truck smoke, did it sit for long periods of time, etc.
Good news is you will be putting in a new thermostat, fresh rings at a minimum, proper fresh oil, timing the IP, perhaps fresh injectors, fresh diesel, and that really leaves looking for smoke issues and watching your temps. But if rolling coal after the rebuild you will want to address that.
itmmik
south carolina
i know the truck the guy just had trans rebuilt 122 miles on it was running saw him driving it. he bought rebuilt injector pump after in quit running tried to fix it. look like proper maintenance was not done some sludge in bottom of pan. engine clean every where else needed glow plugs injectors glow plug controller melted. he bought a lot of other parts too. he tried to fix it took injector pump and housing off he gave up after that . i retime it tried to start no start quit when a saw blow by that was diesel fuel . clean no rust 1989 f350 dually 122000 miles ? on it paid 1500.00 for it price of trucks now i think it worth repairing heads in good shape vales look good no cracks going to fire ring
Big Bart
Tow&Slow
Newport Beach, CA
To you point at $1,500 for a clean rig, it’s worth doing a rebuild on the motor. Then you know you have at least another 100,000 miles on a reliable engine. Then you have a great truck and worst case it’s worth 6-9k if you want to go another direction.
Just a reminder to replace the front and rear crank main seals and do the oil cooler seals. It will be much easier to do so now with the engine out.
