ROCK HARVEY
I looked up the instructions for your fuel pump, and found this:
“The fuel pump must be mounted at or below the lowest point of the fuel tank. The pump must also be within one foot of the fuel tank as it’s designed to push fuel from the tank towards the engine. WARNING: Fuel pump failure will occur if not mounted within the required specification.”
I think you might have your pump too far from the tank. Have you tested the flow by unhooking the hose to the IP and seeing how much fuel the pump is pushing up to the engine?
