6.0l driving me up a wall please help
rustygold
conway Arkansas
Yeah now ipr is 84% with icp at 200 like the ipr is stuck open.
Makes me wonder if the PCM is bad don't have a pressure gauge that goes up to 4000psi so I can't tell if it's true or not
Sent from my SAMSUNG-SM-G870A using Tapatalk
rustygold
conway Arkansas
Thought this was cool
Only problem with that is most I've seen tap into the ICP sensor. So if the ICP sensor is bad, well......
You can go to a hydraulic shop and get a cheap mechanical gauge.
rustygold
conway Arkansas
I got it to start 3 time's today I wonder how the oil goes to the hpop sump.
Is it a little hole or a vein and could that get clogged as well??
rustygold
conway Arkansas
That's awesome thanks I'm going to take apart the oil cooler and get it clean.
I'm going to do that monday I think if I touch the truck again I might kill it.
rustygold
conway Arkansas
Here's what the screen looked like. I also pulled the rails and found grit it has to be that screen so clean top injectors runs great now after I did another top end clean. Probably going to have to buy 8 injectors later but it runs now.
If it ain't broke don't fix it
rustygold
conway Arkansas
Well I spoke to soon now I think it's the computer look at this and when I look at signals I can see them in run but everything goes blank. I'm starting to think PCM
Green is camshaft and crankshaft sync
Blue IPR
yellow ICP
rustygold
conway Arkansas
Well it ran and ran for a while.
Few days it did. I'm done with it
