1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
2001 7.3 has oil pressure and fuel pressure still no start new ipr,icp,hpop.no codes
Discussion in '7.3L Powerstroke Diesels' started by coailminer, Jul 20, 2019.
  1. coailminer
    coailminer Registered User
    Nov 25, 2017
    tennessee
    need help
  2. Oledirtypearl86
    Oledirtypearl86 Full Access Member
    33
    1,022
    486
    Sep 17, 2018
    Whitehall MT
    Any smoke from exhaust and whats oil pressure at cranking
  3. BR3
    BR3 Full Access Member
    328
    94
    Nov 19, 2013
    Mt.juliet , TN
    Cam position sensor?
  4. coailminer
    Nov 25, 2017
    tennessee
    no smoke 1000psi
  5. coailminer
    Nov 25, 2017
    tennessee
    put a new one on it
  6. BR3
    328
    94
    Nov 19, 2013
    Mt.juliet , TN
    Done a compression test?
  7. Oledirtypearl86
    33
    1,022
    486
    Sep 17, 2018
    Whitehall MT
    @coailminer how was it running before it shit the bed
  8. 79jasper
    79jasper Chickenhawk
    26
    16,378
    1,424
    Oct 13, 2012
    You should double check on fuel pressure.
    Next would be give the idm a shake to check for water, check the pcm fuse and unplug the fuel heater, also check the valve cover harness plugs.
    Oledirtypearl86 likes this.
  9. greenskeeper
    greenskeeper Full Access Member
    485
    56
    Mar 16, 2013
    hatfield pa
    WTS light when key on prior to starting?
    If so, pull one (preferably both) valve covers and crank the engine over. Is oil spurting from the injectors indicating they are firing?
Share This Page
