troupp
Ok, so the 2"body lift is done. I had to lengthen my 4wd shifter, now it works fine. But I can't seem to make the zf's shifter work for squat on any of the back 3 gears. I've clearanced the floor as per the lifts instructions, to no avail. Ive cut the lower shift boot, to allow it to flex more as I thought it was binding the shifter up, and I removed the upper shifter boot and left it loose from the floor, still 2nd, 4th and reverse don't want to shift decent... had no problems before lift..
Any thoughts or proven fixes?
It was easier than bending and cutting stuff, and fixed the problem perfectly. Just made it out of a piece of stock and cut threads in it so there would be no need for nuts. I'll probably have to do the same for the Moosestang. The problem is, when you do the body lift, your fulcrum point for the shift lever is lower, consequently the swing of the lever is greater. We found that the boot had a tendancy to "bunch up" and keep the lever from moving adaquately. The lever lift solved that problem.
